Hi Froum,
is ist possible to use 2 XP10 Controller with 1 USB Hub?
My PC has only 2 USB ports but one port is still reserved fo the Bluetooth USB Desktop.
Thanks for your feedback
JayDee
JayDee
Posted Wed 10 May 06 @ 4:23 pm
I use them with a USB Hub without problems. BUT adopt a powered USB Hub if you want to be sure it will not mess up your config....
XP10 like very stable DC power..
Posted Wed 10 May 06 @ 4:37 pm
Buy a 2.0 USB adapter...they are cheap cost under 15 bucks!!!
Posted Fri 12 May 06 @ 5:05 pm
and be sure it is a poowered USB 2.0 HUB, as slash saids, it's better.
Posted Fri 19 May 06 @ 8:25 am
