Hi - this is probably a stupid question, but does anyone know if the Stanton Final Scratch Soundcard can be used with VDJ??
Asymptote
Asymptote
Posted Mon 01 May 06 @ 6:24 pm
I think I heard somewhere that the Finascratch soundcard has Asio drivers. If so they could probably be used with VDJ. The Timecode vinyls will not work, You will need the VDJ timecode vinyls instead.
Ewout
Ewout
Posted Mon 01 May 06 @ 7:55 pm
Think the FS soundcard is kinda locked to the FS software...
But you can give it a try, or try the www.asio4all.com driver, and see if that one picks up the FS soundcard as a windows soundcard
Posted Mon 01 May 06 @ 8:22 pm
FS gear would be quite usefull if it were able to be used with Virtual DJ, as, unfortunatly, I can get FS gear 100 times easier than VDJ.. :S
Sean
Sean
Posted Tue 02 May 06 @ 12:45 pm
About fs2 firewire scratchamp i know it has asio drivers and i've seen it working with other programs too.
But i don't think its the same with fs1 scratchamp, this used a crappy philips card with inverted inputs-outputs or something like this.
Posted Tue 02 May 06 @ 4:32 pm
Yes it's possible with the FS2 scratchamp as it has native ASIO drivers. I think it is possible also with the FS1 scratchamp, but you have to completely uninstall everything Traktor-related and use something like the asio4all drivers. However, from what I hear the FS1 scratchamp sucks as a normal soundcard.
Posted Tue 02 May 06 @ 5:23 pm
I've got a friend who's got one and thought I might try it, because I already have the 'other software' but would not ever want to give up using my TCCD on VDJ. I have a Maya 44 already and am totally happy with it..
Posted Tue 02 May 06 @ 11:00 pm
scratchamp 1 is not better than your maya,... don't bother.
Posted Wed 03 May 06 @ 12:23 pm
