When i got new songs and analyze and mayby set a comment to the new songs. When i then close down vdj it only save 90% of the new bpms and the comments after that i must start vdj one more time and analyze one more time and make comments one more time then it works. Is there enyone that have the same problem or can tell me whats wrong
regards
JH444 = DJ_JH
regards
JH444 = DJ_JH
Posted Sun 23 Apr 06 @ 11:31 pm
Hi,
Wondering if you are in local database or from a folder when you analyze?
I reported similar, but I cannot duplicate your issue.
I believe it has to do with the xml file loaded into memory.
VDJ does not write to the xml till program exits.
-Dj Los.
-Dj Los.
Posted Mon 24 Apr 06 @ 1:26 pm
Forgot to mention, in general tab, check to see if you are using "read id3 tags" and "write vdj tags"
Also, you can browse the xml file for those songs that do not have bpm and see what the entry looks like.
-Dj Los
-Dj Los
Posted Mon 24 Apr 06 @ 1:50 pm
hi
Thanks for the answer, im not using "read id3 tags" and "write vdj tags" and i have the music in a folder of my external harddrive. Before i did have the music in a folder of my pc but i still have the problem.
PS. i will chek the xml file next time i analyze songs
regards
JH444=DJ_JH
regards
JH444=DJ_JH
Posted Mon 24 Apr 06 @ 3:13 pm
I just changed my setting for read and write tags to "disabled".
I then opened a folder, analyzed and exited, started VDJ and all data is there.
Not sure how to test this for you since you said some bpm's are not saved.
Perhaps someone else has more ideas.
-Dj Los.
-Dj Los.
Posted Mon 24 Apr 06 @ 4:19 pm
Thanks anyway i hope someone els having some idea its very irritated to have to fix whith the bpms 2 times every time
DJ_JH
DJ_JH
Posted Mon 24 Apr 06 @ 10:42 pm
