Topic: headphone/speaker splitter for a pc
anyone know where i can get one from so that i can properly mix on my pc??
Posted Fri 21 Apr 06 @ 5:53 pm
xeonPRO InfinityModeratorMember since 2004
I can't reccomend you use a splitter for headphones and audio out. You will get only mono signal (not left & right).
If you really want to use it, search the net or go to the music store of hardware.
It's better to use 2 sound cards or 4.1 card which is not expensive.
Posted Fri 21 Apr 06 @ 7:27 pm
And you need the full version of VDJ to preview a song, the demo version don't allow that
Posted Sun 23 Apr 06 @ 8:24 pm
I think a cheap 5.1 sound card is a better solution than a splitter cable. This is ok for home use. You will need the full version for this solution.
Ewout
Posted Sun 23 Apr 06 @ 8:35 pm
