Topic: Automatic volume changer
hey does anyone know of any hardware or software that will automatically change the volume of the songs on a timed schedule,
why i ask this is because i have been asked to do the setup for a lounge and the manager doesn't want any of the regular staff touching stuff and so he asked me if when a d.j. is not there if it is possible to have the volume automaticall turn up when it gets to 6 pm in the evening and automaticall lower itself in the early morning hours
please help me soon
d.j. squeeze eye
Posted Tue 11 Apr 06 @ 5:41 am
This could be possible in a plugin, using the master sound level and the time.
or a remote controlled soundcard. but thats another cost.
CAN ANYONE ELSE HELP ALSO
If you're any good at soldering and electrical stuff, I could draw you a simple circuit that would do it using a standard plug-in timeswitch.
You use the timeswitch to trigger a 240v relay. The relay contacts could then be used to switch in either a fixed resistor or potentiometer into the master stereo output from your audio source. Components needed - a small project box, a 240v DPDC relay, a potentiometer (i would suggest 10K linear), some wire, and a domestic timeswitch. Let me know if you want to know any more!
^^ im sure you helped him.. lol
show your boss the volume nob and im sure he can figure it out.................................
