Topic: Best effects?
funnyb0nzPRO InfinityModeratorMember since 2006
ANyone tell me what the must have effects are? I hope version 4 will allow me to use the effects on my dennon 3500's. However if I have to settle with plugin's that I can map via midi to my ecler nuo4 that is fine. Just curious to what the hottest effects are.
Posted Sun 09 Apr 06 @ 1:29 am
Dj XeoPRO InfinityMember since 2005
I can tel you for free there is no way that the effects on your 3500s wil be useable with VDJ
unless you can hardwire an input directly into the signal path before the effects processing unit and use it on an effects loop from the outputs on your soundcard but im guessing no on that one
Posted Sun 09 Apr 06 @ 3:22 am
hmm, now your shedding some light. I have the emu1616m, and with its software I should be able to do something via iso. I will have to toy around and see what I can come up with. Thanks for the feedback
Posted Sun 09 Apr 06 @ 2:49 pm
