hey so if I want to download another copy of vdj onto my comp how can I do that?
thanks
thanks
Posted Sat 08 Apr 06 @ 10:37 pm
you can contact e-service: http://www.virtualdj.com/contact/
Posted Sat 08 Apr 06 @ 10:44 pm
Keep the Install file on your computer safe, but if you should lose it, another download can be made possible easily and quickly at e-service :).
And welcome to the forum/ as A new user.
Posted Sat 08 Apr 06 @ 10:46 pm
I just right clicked on download link and clicked save as to a jump drive. The installer will always be there if you should ever need to reload. This is way better. Keep a copy of your reg number on a note pad on the same drive. At least that is what I do. I can't remember otherwise. Hope this helps!
Posted Sun 09 Apr 06 @ 6:46 pm
I use an external harddrive. I created an Essentials folder on it, with the VDJ install files and the upgrades, also a textfile with the serial. Also the Maya usb drivers. In this case I always could reinstall ,also before gig in case of trouble. Never needed it really, but just in case.
Ewout
Ewout
Posted Sun 09 Apr 06 @ 9:52 pm
