I have two Tecnics 1200's, Rane TTM 54 Mixer, and Maya 44 USB soundcard. I have Pyle Pro powered speakers. My computer is a Dell Insiron 8600 with 1.25GB Memory and Intel Centrino 1.5gz chip. I bought the timecoded vinyl (2).
I had trouble hooking all of this up. Can someone give me step by step instructions how to do this? I'm sorry to ask, but I have used Rane Serato Scratch, and frankly it's a lot easier to get up and running due to no need for Y splitters, all the RCA's, and the external soundcard. Thanks in advance.
Posted Wed 05 Apr 06 @ 8:29 pm
check this
https://virtualdj.com/blog/Dams/blog738.html
it's basicly the same, you only need Y adapters if you playing real vinyls
you will need 4 of them
split each of the turntable outs so you can plug L/R into the phono of the mixer and also the IN of your MAYA44
if your just using TCV then no need just plug in MAYA44 only
Posted Wed 05 Apr 06 @ 8:39 pm
THAT LINK IS NOT FOUND
Can someone please update
Posted Mon 24 Apr 06 @ 10:33 pm
link works fine... it's probably only available to registered users, some posting require a certain user level.
you can try this one if you want to inquire more
https://virtualdj.com/products/timecode/
Posted Mon 24 Apr 06 @ 10:39 pm
is the maya44 the only sound card that can be used if not which other ones are out there?
Posted Wed 26 Apr 06 @ 2:12 am
My question is I don't need to play vinyls just TCV. Exactly what cables do I need and how and where do I hook up?
Posted Thu 24 Aug 06 @ 12:24 am
Hi,
RIght deck out in Maya in 1-2 (RCA Wire)
Left deck out in Maya in 3-4 (RCA Wire)
Output Maya 5-6 in Mixer Line-in right side (RCA Wire)
Output Maya 7-8 in Mixer Line-in Left side (RCA Wire)
Master Mixer in Speakers.
Dont forget to ground your turntables on your PC.
Karlo.
Karlo.
Posted Thu 24 Aug 06 @ 3:12 am
Straight from the Help Section above, under User Guides.
Also, check out the blogs.
https://virtualdj.com/support/VirtualDJ%203%20-%20Advanced%20ASIO%20configuration.pdf
Posted Thu 24 Aug 06 @ 3:49 am
