Hey folks...;o)
Just wondering if someone can help me. I've just started on Naptser To Go and note that I can't play my Napster downloads on 3.1, which is what I use, but I can on 3.4. Is there anyway I can put the same extension onto 3.1 to play my Napster tracks on 3.1???
I don't want to go to 3.4 just now cos I've noticed some response issues (purely related to my pc) but I don't want to not be able to play my new downloads.
Can anyone help???
Cheers...and keep spinnin'...:o)
P
Can anyone help???
P
Posted Sun 02 Apr 06 @ 3:50 pm
I think that without upgrading to 3.4 your only option would be to open napster up in a separate window and play them from there, burn and rip them all back in, or wait until 4.0
Posted Sun 02 Apr 06 @ 3:58 pm
now you got me curious.. I just cancelled Napster.. they would not let you burn them unless you paid an extra 99 cents each.. so why should I play the 9.95 month.. I thought I could use them but didnt' think so .. so I'm just buying them at the 99 ... is there a better way... are you saying with 3.4 if I pay my 9.95 month I can play those songs... in Virtual DJ 3.4
Posted Sun 02 Apr 06 @ 7:43 pm
Well, check this!
I've been on the Napster message boards and found the following out:
* It's £9.95/£14.95 per month for unlimited downloads
* If you want to burn the tracks to cd, you have to PAY an additional download fee (like 0.70 - whatever it is)
* Unlimited downloads can be played on your pc/mp3 player (compatible mp3 player only - recommended by Napster) for as long as you have a membership
* This for me is a belter!!! Apparently songs are taken 'off' the Napster database. And, seeing as you don't technically 'own' them if you don't purchase them quick smart, if you have downloaded a track and they remove it, it won't play on your system, even if you still have it there...where's the use in that!?!?!?
Already I'm thinking about cancelling my trial version...:o(
P
P
Posted Sun 02 Apr 06 @ 8:34 pm
Is there anyway 3.1 can be made to recognise tracks downloaded from Napster? Is it an extension add on or is it actually something in the programming of 3.4 itself???
P
P
Posted Thu 06 Apr 06 @ 8:33 pm
It's in the programm itself.
So no, 3.1 can't be made to support tracks from Napster.
Posted Thu 06 Apr 06 @ 9:02 pm
