Hi,
I've got a problem / question:
I use Hercules MK2 (with latest firmware/drivers) with VDJ 3.4 (DJConsole edition). When I put sound from console to main mixer and play music through simple winamp, it's OK, i.e. volume is normal just like CD deck. However, if I play through VDJ, it's much lower. I've checked all settings and everything, no dice.
anyone any ideas?
Thanks!
anyone any ideas?
Thanks!
Posted Mon 27 Mar 06 @ 11:34 pm
Nobody else have the same problem? Weird...
Posted Tue 28 Mar 06 @ 7:23 am
Try to increase the gain of the deck in VDJ, winamp have only the volume regulation.
Posted Tue 28 Mar 06 @ 8:25 am
In VirtualDJ 3 DJC Edition configuration, go in the FAME parameters panel and set Auto-Gain on "Always 0dB".
Posted Mon 03 Apr 06 @ 8:32 pm
Yea, that's what I did at the beginning. Then I started doing "always match" and crank up gain to like +5.0, seemed to help.
Now, I just got external mixer and all problems with lower volume went away :)
Posted Tue 04 Apr 06 @ 3:51 pm
