Topic: HERCULES DJ CONTROL MP3
brennieHome userMember since 2006
I NEED HELP I GOT THE DJ CONTROL MP3 AND THE VIRTUAL DJ THAT CAME WITH IT BUT I DON GET NO SOUND ON HEADPHONES IS THE VIRTUAL DJ THAT COME WITH OK OR DO I NEED A MUSE POCK LT WILL THAT WORK WITH WHAT IV GOT????????????????
Posted Sun 26 Mar 06 @ 11:41 pm
you need a SOUNDCARD ;)
The Hercules mp3 controller DOES NOT have a soundcard built-in, but supports the use of ONE soundcard (with the dedicated VDJ console version).
This one soundcard needs to be a 4.1/5.1 soundcard if you want to prelisten a deck before you mix.
You then use one channel out for master, and other channel out for prelisten
hope that helops :)
Posted Sun 26 Mar 06 @ 11:48 pm
MANY THANKS DO YOU KNOW IF THE MUSE POCKET LT SOUNDCARD WORKS?
Posted Sun 26 Mar 06 @ 11:51 pm
the MUSE POCKET LT works fine ;)
its a cool little 5.1 external usb soundcard :)
You would then have master sound out on channel 1/2, and prelisten to the other deck on the sub-wof/back output
Posted Mon 27 Mar 06 @ 9:17 pm
thanks for all your help it works love it now i can mix some old skool
Posted Tue 28 Mar 06 @ 12:15 am
