Ok, 3.3 worked fine for me but just upgraded to 3.4. I am using Emu1616M with my internal sound card on laptop disabled in bios. I have 2.8 ghz P4 with 1gig ram.(Sony laptop). What is happening is when playing, I am getting some skipping (at least that what it sounds like). Does anyone have any ideas, and also what the best setup for tccd is? I am using my asio that came with emu1616m. I dont have problems with other sound software just VDJ.
Posted Sat 25 Mar 06 @ 3:36 pm
1) Disable the master tempo
2) Max Load at 15-30 min
3) Verify your sound card is in 44.1kHz , 16 bits
4) Do you only use one usb item at the same time?
Posted Sat 25 Mar 06 @ 3:48 pm
I use more than one usb, I have to have usb for external hard drive, 1 for ecler nuo4. I havent changed anything from 3.3 to 3.4. Disabled master tempo (is this only capable from within the skin and not config)? Sound card is 44.1khz, 16 bits
Posted Sat 25 Mar 06 @ 4:00 pm
