Well, i had no warranty of my console cause i've bought it on 2nd hand. I have opened and changed the system of buttons with some microswitch. Now it works perfectly and the design is not changed. Problem solved totally for me.
DjKad
DjKad
Posted Wed 22 Mar 06 @ 6:52 pm
What problems did U have?
Posted Wed 22 Mar 06 @ 7:30 pm
play & cue buttons sometimes worked, sometimes not. now all things works good. I have made an html-guide with pictures of every step for the mod but i dunno if i can post here the link. It's written in italian but if somebody think it's useful, i'll translate it.
Posted Thu 23 Mar 06 @ 1:05 am
I'd like to see this guide (even in italian), and the microswitches you used.
Posted Thu 23 Mar 06 @ 2:08 am
Posted Thu 23 Mar 06 @ 3:00 am
Hey, can u tell me which one of the consoles is better Mk1 od that mp3 in your opinion? I mean hardwarelike, which has better quality?
Thx!
Thx!
Posted Thu 23 Mar 06 @ 6:54 am
Voltron,
As you had already disassembled the Console, washing the carbon contacts (the black dots you removed at the rear of the Play & Cue keys) would have offered the same result: the reason why the Play & Cue keys become unreliable is mainly the fact the 2 carbon contact points below the buttons become a bit dirty (because of smoke or rust), so washing is efficient.
Posted Thu 23 Mar 06 @ 11:39 am
i did but it didn't work, and btw now is much better. The feel is changed. it seems u r using a more professional tool
Posted Thu 23 Mar 06 @ 4:33 pm
Nice guide, thank you.
Here is an "automatic" translation of your site using google language tools.
http://translate.google.com/translate?u=http%3A%2F%2Fvoltron.osdealer.com%2Fmodhdjcmk1%2F&langpair=it%7Cen&hl=en&ie=UTF-8&oe=UTF-8&prev=%2Flanguage_tools
Posted Thu 23 Mar 06 @ 5:23 pm
Thanks bro, sorry for the pictures but my camera is old. I'll try to translate it better cause some terms are not translated. I hope that hercules will change the mechanism of buttons cause a friend has told me that mk2 still have the same type of buttons. I wanna find a good site for order miniswitches cause i have taken them in a old television. I'll give u tha link or the specification
Peace DjKad
Peace DjKad
Posted Thu 23 Mar 06 @ 8:35 pm
The Voltron friend is here, I can confirm the MK2 button it's the same of the MK1, after 6 months of work no problem but is not a very precision button.
Probably after the warranty period I will change the botton like the Voltron modify.
Posted Fri 24 Mar 06 @ 8:47 am
Anyone know of an englist site with these instructions?
The translation is not very good
Posted Fri 24 Mar 06 @ 9:16 pm
Sup bro,
If u wait one or 2 days i'll translate it in english.
Cya
DjKad
Cya
DjKad
Posted Fri 24 Mar 06 @ 9:45 pm
It's an automatic translation by a robot...(google) that's why....
Better translate only the parts that are not well translated, i guess it needs too much work for thewhole page.
Imo, is not needed, pictures speak by themself..
Posted Sat 25 Mar 06 @ 2:57 am
Hi Voltron / Ciocce,
DJ Console MK2 buttons are not the same as on MK1: there are 4 carbon contacts below the Play and the Cue keys on DJ Console MK2 instead of 2 contacts on MK1.
Posted Mon 27 Mar 06 @ 11:42 am
Thanks Made In Breizh for the info, now I can undestand but I prefer a switch button for contact of the play button and the cue.
The other buttons work fine because is a little botton.
Posted Tue 28 Mar 06 @ 8:28 am
