I am working on a new plugin based on filter.
I have this kind of problem when if I use a Low Frequency Oscillation(in numbers of Bpm less than 1) the effect of plugin does not start very quick, but after one/two bpm after launching plugin.
the same problem when I change one parameter (button or slider) whereas the plugin is used.
for example: trans effect.
If the LFO is > 1 bpm, it sounds ok
Otherwise (LFO = 1/4 Bpm), there is like a latence of the plugin .
Posted Mon 13 Mar 06 @ 9:02 pm
