Topic: voice changing devices
im just wondering if anyone knows if there is a way 2 change the vocals on a song or is it impossible for this software :P
Posted Sat 11 Mar 06 @ 4:48 pm
well it depends what you want to do, like, if you go to Settings, then under the Fame Settings tab, disable timestrectch, and when you slide the pitch slider up or down you can get that really deep voice, slow pitch effect, and vice versa if you slide it down
thanks u have been a big help 2 me :)
