Forum: VirtualDJ Skins
Topic: JB - 706106 - XL - Page: 2
thanks djjb, as soon I have a little time I will take a snapshot of the gui and modify it with photoshop so that it will be clear what I need.......but......then, is there a way to upload a file?
via e-mail..
just sent it to me via e-mail
"holy moly"
that skin is really great. most definitely using it
my only thing would be that the loop buttons are reallllly hard for me to use... any chance of you making a skin minimizing some of the other things and making individual loop buttons for each loop length? or at least the common loop lengths
keep on with large 1024 skins!
I've been trying to find your email address but I couldn't.
johnbeerendonk@hotmail.com or
@gmail.com
it's in my blog to
@djjb
I have just tested your skin multi-instance (1 browser) and i get the crashguard when loading twice the multi-skin
Can you verify you have the same problem please
And there is no beatlock button so you can't use the network synchronysation
@djcel
there are 2 beatlock-buttons for each player. it's master and slave.
i never had this error, but when i opened it after your reply here i see this damned smiley.
when i opened it for the second time it whas good.
i think it's because of the browser.
it was the browser..
uploaded again.
with another skin in the package. the browser-skin with no rhythm.
is it right dj cel that the skin is off. from the download page?
Your last package has been activated :-)
thanx mate..
but there where some litle bugs in some skins. so i have already send another update.
hahaha...sorry for that.
john
ps: thnx for the gread work there.
Thanks for the skin. This is the skin i have been waiting for a real long time.
I'll try it at home this weekend.
Tested it quite fast on my 1024x768 laptop and although i didn't get all the screen it sound Great :D
Just can't wait untill this weekend now.
I'll try to find some time to make some tweaks on the skin to only have the things i need on it.
I'm really happy i asked for a multi instance skin with only one browser, and you were able to make it. Thanks AGAIN!
@ paolo..
check your mailbox.
So mixed with the skin yesterday night on Virtual DJ Radio. And I experienced some "problems".
No gain nob on the skin, so i had to change the skin for each instance of VDJ in order to change the gain and then switching back to the multi-instance skin.
There is no Elapsed time and/or Remaining time for each deck. Wasn't really a problem but it could be usefull.
I'm not sure we can set buttons to change the waveform zoom to some value, but it would be very usefull to have the zoom of both waveforms to the same zoom value.
The waveform seems a bit too big. And I don't like the colors. I changed them to the default Green and Red from the default skin.
Although i'm writing all these "bad" thaughts about the skin, it still is an awesome skin. I'll make those changes for myself. I'm still very happy you made this skin. And it is really good for 3 or 4 decks mixing.
@ jeremk
I will insert those things you said...
some things i forget..
greatings
john
my skin is gone from the downloadpage ? :-(
esto es una cagada
How can I get this SKIN?
