When using auto mix, can you shut off the beat matching feature? Sometimes I have a list of random videos that shouldn't be beat matched.
Thanks,
Greg
Thanks,
Greg
Posted Wed 08 Mar 06 @ 1:13 am
Sure you can :)...
Settings - FAME settings - Auto BPM > OFF
Alter the Fade length in the same window to counter the transition sounding off beat, for a jukebox effect it's best to set fade length to 0, also Enable Force Fade.
Hope that helps.
Hope that helps.
Posted Wed 08 Mar 06 @ 1:21 am
Thanks. That's what I was looking for.
Greg
Greg
Posted Wed 08 Mar 06 @ 6:29 am
