I have a problem setting up the multi-instance option so I can use the TC vinyls and my XP10 at the same time using different channels (4).
1) I can't get the desired display from the skins, they overlap on each other instead of being 1 up and the other down.
2) How can I split all 4 players in 4 differents channels.
If there is a link that can answer my questions, I'll appreciate if a member or a staff post it, otherwise, need some assistance.
Posted Sun 05 Mar 06 @ 11:15 pm
You can use my skin multi-instance to get 4 decks
(disable full maximize of the skin)
Posted Mon 06 Mar 06 @ 1:15 am
Actually, I do use your skin, and I just downloaded the upgraded one. They both (the up and down) do overlap on each other and they do not occupy the full screen.
thanks, for responding
Posted Mon 06 Mar 06 @ 2:08 am
it should set the two skin at the good place
Verify as i said if your skin is in full screen or not: disable the full screen on both instance
=> i'm sure it's your problem
Posted Mon 06 Mar 06 @ 5:59 pm
Thanks, DJCEL I got it working. Now I'm using both TVC and the XP10s.
Thanx again,
piyo
Thanx again,
piyo
Posted Thu 09 Mar 06 @ 1:17 am
the only thing though, it does not take the hole screen (15.4''). but I can do what I was aiming for
tx
tx
Posted Thu 09 Mar 06 @ 1:20 am
