Hallo
I think about bying the last version of virtual dj, so I tested the trial version.
I like the Napster plugin but I found several bugs so the Plugin is not very useful...:
1. When I try to play a song direktly from Napster (without downloading first) often virtual dj shows only a "Error" :( Direktly in the Napster software I can play the songs!
2. The pitcher don't work with wma+drm :( If the automixer uses the pitch to sync the bpm I cannot change the pitch after the song started to play
When this problems are solved you will have a new (old [dj consolte]) customer!
Miles
Miles
Posted Thu 02 Mar 06 @ 2:53 pm
Why are you reporting about the trial version?
the pitch works fine with wma's.
disable the beatlock and you can move the pitch slider again.
can't comment on the global database because i don't use it. But i'm sure it works fine!
Posted Mon 06 Mar 06 @ 1:43 pm
