a few weeks back i was cleaning ma virtual dj playlits deleting the ones i didn't like n i axidently deleted the skin on my virtual dj n now when i try to launch it..........a little window pops up n sais "invalid skin file( error line %i in the xml)" so thats what i get n i tried to down;load n install it but it don't work i need step by step help. If sumone knows can they plzz tell me??
Posted Tue 28 Feb 06 @ 12:05 am
First of all, if you don't know how to write correct english, as you are from Canada i assume you speak french, then go to the french forum.
What version of VDJ are you using?
You are better to uninstall VDJ and then reinstall it from the original file to solve your problem.
Posted Wed 01 Mar 06 @ 7:32 pm
