Hi people
After a long period of indecision decided to buy yesterday this little piece of equipment HERCULES DJ CONTROL MP3 but I'm a little bit desappointed, but maybe that's because I'm still learning it.
In any case do you guys know if the keys marked 1,2,3 for FX,CUE,LOOp light up when are activated also do I always have to press on the MASTER TEMPO to sincro the 2 songs, I don't really like the way to load the songs via the jog stick I prefer the enter keys on the pc.
I need to buy an external sound card nothing to expensive, so that I can listen to the heaphones any sugestions are welcome.
Look forward to some tips.
Cheers
Cheers
Posted Sat 25 Feb 06 @ 7:44 pm
1. If you want to monitor the decks on your headphones, go here > http://www.virtualdj.com/blog/acw_dj/
2. In the manual you can find out how to enable/disable the ministick.
3. Don'worry about the mastar tempo, don't use it! If you want to set the BPM, push the the buttons next to the wheels. (because its just temporary)
If the are some strange change inside the music, the kicks wont be on the little squares. So I dont prefer the beat lock, and I never use it. Use the jog wheels to nudge!!! (in the config menu you can find that option)
4. I use the 123 buttons to apply effects
5. use this skin: http://www.virtualdj.com/addons/download.html?addon_id=617
Posted Mon 27 Feb 06 @ 3:51 pm
Hey dj paul f try my skin http://www.virtualdj.com/addons/skin.html?id=1612
It's optimized for DJ console with more plus option to djjb original skin and if you want to "map" the button and sliders try the DJC mapper v2.0 http://www.virtualdj.com/addons/view.html?type=sound%20effect
ONLY FOR PROFESSIONAL USERS
Posted Mon 27 Feb 06 @ 4:12 pm
Thank you for your suggestions I will try them today when I get all my gear back from last night gig.
Man best party ever (CARNAVAL) played non stop from 22H00 until daylight 7H00 in the morning more than 450 people enjoyed the sound and the owner of the club was more than happy, acttually I had to start playing some crapy tunes for the people to go, otherwise I will still be there.
Just one small problem with the program, and that was because the song I loaded was to long about 10 minutes, and at the end the computer got a little bit stuck but I was prepared for that problem solve in seconds.
Posted Tue 28 Feb 06 @ 4:12 pm
