Hi, i just bought the full version of VDJ, but the problem is i can't set the headphone but somehow i can set the headphone now but the volume is verly low (i don't know whether my setting was right or not?)
For your info, i am using Realtek soundcard, and 2.1 stereo speaker.
Thanks for your help and sorry for my bad english language
Posted Tue 14 Feb 06 @ 12:29 pm
The output of a soundcard is a line signal. So if you attach a headphone to it it has a very low output. You could attach an amplifier to your soundcard output. Then you attach your headphone to the Headphone output of the amplifier.
In most cases a friend or relative will have an old amplifier that you could borrow, get or buy.
Ewout
Ewout
Posted Tue 14 Feb 06 @ 12:45 pm
what is the best soundcard for virtual dj?do i need stereo splitter?
thx
thx
Posted Tue 14 Feb 06 @ 12:55 pm
@sharkboyz
follow this link to find out how to set up your headphones.
http://www.virtualdj.com/forums/45926/Hardware_Technical_Support/Can_t_figure_out_how_to_pre-listen_____.html?
One of the best would be something like the audigy platinum or any 5.1 sound card. I use an audio extreme 5.1 and it gives really good sound quality. With a 5.1 sound card you won't need a splitter.
Hope this helps
Nikki
Hope this helps
Nikki
Posted Tue 14 Feb 06 @ 12:58 pm
I use one of these on my back up rig.
http://www.zzounds.com/item--RLLPM50S
Posted Tue 14 Feb 06 @ 1:18 pm
You must have a headphone with a resistance of less than 30 Ohm
Johan
Johan
Posted Tue 14 Feb 06 @ 1:39 pm
