Hi! I'm thinking about purchasing this program, but I can't seem to get my headphones to monitor the second track. I have a SoundBlaster Audigy 2 ZS Plat Pro soundcard, and I understand that I should be able to do this. Help! :)
Posted Wed 08 Feb 06 @ 12:51 am
To monitor the second track on the headphones you need to buy the software, it isn't possible in the trial version.
I see you are posting on the atomixmp3 forum, is it atomixmp3 or Virtualdj you are about to purchase?
if it is atomixmp3 consider having a look at virtualdj.com it is a far better software than atomixmp3.
Posted Wed 08 Feb 06 @ 12:59 am
Not sure if you can monitor with the DEMO version
Posted Wed 08 Feb 06 @ 1:00 am
Yes.. if I need the full version how will I know if it will work?
And I've tried Virtual DJ...
If you have two stereo outputs on your sound card or with two soundcards it will work, nobody has yet had a problem to monitor the track in headphones when they bought the software.
Posted Wed 08 Feb 06 @ 1:05 am
OK, so what you're saying is my soundcard should be good enough? It does have several outputs.
Posted Wed 08 Feb 06 @ 1:27 am
yes your soundcard is good enough. No problems have ever been encountered with the Audigy 2 ZS.
Posted Wed 08 Feb 06 @ 1:42 am
Thanks! :)
Posted Wed 08 Feb 06 @ 1:56 am
I recently bought the PCMCIA version of the Audigy, and it freakin' rocks. You won't have any issues, except maybe some skip issues common with .wav's (use mp3's), or USB hardware... or some such that just can't be pinned down like peeps like me experience.
Posted Wed 08 Feb 06 @ 8:12 am
I use an Audigy 2 ZS Platinum with VirtualDJ, the sound is perfect and also have Headphone CUEing and great sound in the master output. Also I use time to time with my external mixer, no problems.
Hope see you soon as a full VDJ user.
Posted Wed 08 Feb 06 @ 11:09 pm
