hey,
what does the vinyl ripping program do?
thanks
thanks
Posted Thu 02 Feb 06 @ 4:48 am
As the name says, it's for RIP your Vinyls.
Helps to rip them from the line input of the soundcard.
If you press CONFIG you can setup:
- Wich soundcard to use
- Wich GAIN to do.
- What time of SILENCE to wait before AUTOSTOP
- A bit of PREAMP
You can also select AUTOSTART, so it starts to RECORD when the sound starts, and AUTOSTOP, so it stops to RECORD after the time you config on SILENCE.
Then you generate a MP3 file.
- Wich GAIN to do.
- A bit of PREAMP
Posted Thu 02 Feb 06 @ 11:14 am
so you can make mp3s out of other vinyl that you have?
Posted Thu 02 Feb 06 @ 4:28 pm
Yes
Posted Thu 02 Feb 06 @ 5:13 pm
That's the idea.
It's a tool to help do it, better than an usual record software.
Posted Fri 03 Feb 06 @ 11:35 am
