Topic: other timecode vinyl
does anyone know what would happen if you tried serato scratch timecoded vinyl with VDJ?
thanks
Posted Wed 01 Feb 06 @ 3:44 am
Funky-TPRO InfinityMember since 2006
it's working but no needle droping
Posted Wed 01 Feb 06 @ 4:01 am
djcityPRO InfinityMember since 2005
You get sound. Only sound.
Wherever you put the needle, The place in the song will not change.
The sound quaility is POOR. I can't stress that enuff. It really sounds like some sh1t.
The tempo is MUCH slower.
Like I said... You get sound but it's not worth it and you can't make it any better.
Stick to VDJ tcv's
Posted Wed 01 Feb 06 @ 4:43 am
acw_djPRO InfinitySenior staffMember since 2005
DJ quickhands,
It's a good thing to search in the forums for an answer. In that way you could find more information and a solution that could fit to what you are looking for and you can learn more in that way about VDJ.
This answer is ALWAYS the same. VDJ is only COMPATIBLE with VirtualDJ TCVs or D-Vinyls 2020.
Posted Wed 01 Feb 06 @ 4:12 pm
