Topic: key changer with vdj
dabunnyHome userMember since 2006
Hi
I just started using Virtual DJ and am trying to locate the key changer which I was advised there is for my karaoke.
Where is it located or where are the settings.
Pls help
thanks
Posted Mon 30 Jan 06 @ 1:31 am
go to the config setting--upper right hand corner
then go to keyboard shortcuts
Posted Mon 30 Jan 06 @ 2:24 am
Hi again
I'm still trying to locate the key changer on any of the skins that are listed on vdj (karaoke)
If someone can provide a specific skin that shows the key changer this would be greatly appreciated
I tried the info that Kramer101 provided but I couldn't locate the answer
thanks for your help
Posted Mon 13 Feb 06 @ 1:00 am
Keychanger is NOT included with HOSTER... it is a plugin that you have to download. Inasmuch as you are not a registered user, you won't be able to download it.
If you purchased VDJ, please register you copy then you can go to the downloads section and download it.
Good Luck...
BTW, I use VDJ with the keychanger and it works great.
Posted Mon 13 Feb 06 @ 1:49 am
Is there a key changer that can be purchased for vdj. 3.1 with karaoke?
If I can download it and pay for it then add this to the vdj + karaoke this would be most helpful
thanks
Posted Mon 13 Feb 06 @ 2:16 am
DaBunny,
there isn't a plugin that you can purchase.
If you buy Virtual DJ (http://www.virtualdj.com/purchase/) Then you get the full version of VDJ. Besides this full version you are able to download all the plugins. Also the "key change" plugin.
The version you are using at the moment is a demo that will work for 20 days.
Ewout
Posted Mon 13 Feb 06 @ 6:23 pm
More to the point, the plugins are FREE downloads, included with the price... Many developed by the dj's here.
Posted Tue 14 Feb 06 @ 7:46 pm
Dj XeoPRO InfinityMember since 2005
i sure hope that key integration is put in the next version instead of using a plugin. one that has the same artefact as the old timestretch.
Posted Wed 15 Feb 06 @ 1:08 am
