Hi!
I've searched the forum, but didn't yet found what I was looking for.. I have a Logitech Z-5500 5.1 subwoofer and a built-in in motherboard AC'97 audio (support for up to 8 channels).
My goal is to make in Virtual DJ the active deck's output to all 5 satellites + subwoofer and the passif deck into the headphones. Is it possible with virtual DJ? I have played a lot with custom configurations there.. but didn't get it to work exactly as I wanted to...
I plugged the headphones into "Side Speaker Out" into the soundcard because if I plug headphones into the heaphones all sounds goes there..
The problem is: in custom configurations in Virtual DJ you can only select 1 output (like rear or front satellites.. but not both) How do I make all 5 sattelites and subwoofer to play the active deck??
Thanks for your time to understand my problem =)
Posted Sun 29 Jan 06 @ 11:33 pm
You only have to configure your soundcard and Windows.
The information is available only for register VDJ professional users. sorry.
Posted Mon 30 Jan 06 @ 7:30 pm
