Topic: HEADPHONES
i want to buy comfortable (very important, because i wear glasses) and CHEAP headhpones with good sound quality (important because i need good sound quality to enjoy music and i use Fl studio besides dj-ing). I hate my present headphones i want to change them asap. What about the sennheiser hd200 ?
(or maybe the hd202 or hd212)
And what do you suggest ???
Posted Sun 29 Jan 06 @ 11:23 am
anyone can you help me????
PLZ
Totyo...
Good headphones are going to cost. You can try to split between cost, quaility, and comfort but it will be a very hard split.
Quaility Comfort Headphones:
1. Technics RP-DH1200......................$169.99
2. Pioneer HDJ-1000..........................$159.99
3. Sony MDR-V700............................$99.99
4. Sony MDR-V900............................$199.99
5. Denon DN-HP 1000.......................$159.99
6. Stanton DJ PRO 3000....................$129.99
Inexpensive Headphones
1. Gemini DJX-05..............................$49.99
2. Gemini DJX-03..............................$19.99
3. Stanton DJ PRO 2000....................$89.99
4. Behringer HPX-2000.....................$19.99 (All Behringer headphones are inexpensive)
There are lots more headphones out there at varying prices, quaility, and comfort. My advice to you is to check them out in person if you can. If you can't, try these places
www.pssl.com
www.123dj.com
www.musiciansfriend.com
Hope this helps
thx
i have the stanton dj pro 3000
i like that one, its better than al the previous i had
nice bass, and verry comfortable
you know all the products now are made in china and theres a million knock offs which are just as good. I bought a set off ebay for less then 30 and i couldn't be happier. The sound is great and they are damn comfortable. Just take a look around.
Sennheiser HD 25
made in ireland(not china) designed in germany. nothing else competes, there are no knock offs of these because it just wouldnt be possible.. worth every penny. all parts are replaceable so will last you a lifetime.
