ViperVin,
You really have wrong your antiskating parameter... if you were register you could check my blog for the proper settings in detail. But now, I only can tell you, look into your Technics Manual. Antiskating must be in the same value you got the weight of your cartridge. I wonder if you have the proper settings there too...
The problem is in your current settings in your TTs.
Here are the specs of your Ortofon http://www.ortofon.com/disco/stylus/ccpros.html
You need to put 3gr in the weight and 3gr in the antiskating knob... also. I hope you could balance correctly to weight cero to get the proper weight in the Stylus...
Posted Sun 29 Jan 06 @ 5:14 pm
but what's confusing that i find is that stanton suggests "0" anti-skate on most or all of their stylus.
Posted Sun 29 Jan 06 @ 6:19 pm
Listen2,
Here is the URL and you have to read the antiskating value + Weight Value as "tracking force" also.
http://www.stantondj.com/v2/carts.asp
Posted Sun 29 Jan 06 @ 7:01 pm
