Forum: Old versions
Topic: problem with 3.3 for dj console mp3
hi
i upgraded vdj from 3.2 to 3.3. if i want to start the "vdj the virtueldj_djc.exe " have a problem and the progamm must be terminated. what can i do? i cant download the 3.2 upgrate...
thanks 4 help
bye
Posted Sat 14 Jan 06 @ 6:48 pm
you should probably uninstall everything, reinstall the version provided with the console, then reperform the 3.3 upgrade. if it doesn't work, ask on https://virtualdj.com/contact/
note: if you want to save your cue points/comments/BPMs/..., make a backup copy of the "VirtualDJ Database.xml" file before uninstalling
