I just got my maya44 usb soundcard and I can't seem to install the drivers or the programs for it. The install cd does NOTHING. Can someone walk me thru this please.
Oh, by the way, I'm purchasing the full version as soon as I get the hardware all hooked up and running.
PLEASE HELP ME.
PLEASE HELP ME.
Posted Sat 07 Jan 06 @ 9:35 pm
get the last drivers from the audiotrak site, run the executable and follow the instructions..
http://www.audiotrak.net/download/DRIVER/MAYA44USB/MAYA44USBv2.5.5.zip
Posted Sat 07 Jan 06 @ 10:49 pm
Something that can confuse you, is that the installer ask you to plug/unplug the usb cable 2 times during installation.
That's normal, for this driver.
After installation remember, you have to plug the card always to the same usb port, the one you used when installed the card. Else it will not work. That's a windows issue.
Posted Sun 08 Jan 06 @ 2:38 am
