Hi there...i Have a Numark Mixer and a 7.1 Soundcard...im also plannin on purchasing the DAC controller....I would really like to know what it does and How it helps in DJing. Also, i wanna know how it works and How can i get it to work with my mixer and my soundcard.... Thanks!
Waitng for a rep.
DJ adi
Waitng for a rep.
DJ adi
Posted Sun 01 Jan 06 @ 10:55 am
The DAC-3 is simply a controller controlling many of the features in Virtual DJ, giving a more hands-on feeling, instead of using your keyboard or mouse. You simply plug it in via the USB cable and your up and running. It has nothing to do with the rest of your setup.
Posted Sun 01 Jan 06 @ 3:39 pm
Hmm..ok so i just use it as a controller and the sound output is still from my soundcard..ok..
And what about scrolling through the songs list and finding the songs etc from database? Can the DAC3 do it?
thanks
thanks
Posted Sun 01 Jan 06 @ 4:24 pm
If you use my DAC-3 mapper (Downloads -> Plugins -> Sound Effects), you can use SHIFT+jogwheel to browse through your songs and folders (The default built-in mappings do not allow this.) The up/down buttons on the DAC-3 can also be used for browsing.
Posted Mon 02 Jan 06 @ 2:33 am
If you do other things with your computer while VDJ is playing, a nice thing I found about the DAC3 is that you don't have to have VDJ in the forground to (the active application) to start and stop a deck. I have other programs I use during a show (like excel) and it is nice to know I can just hit play and it works.
Posted Mon 02 Jan 06 @ 6:18 am
Thats good...thanks!
Posted Mon 02 Jan 06 @ 3:13 pm
Can the DAC2 controll regular cd players like denon or pioneers...?
Posted Sat 07 Jan 06 @ 10:12 am
no... it can only controll software
Posted Sat 07 Jan 06 @ 11:27 am
