Hi!
I have a big Problem with the Hercules DJ Console MK2. All Updates are done. The Crossfader doesn't work fine. If I turn it to the left side, Virtual DJ looks like this (look at the Crossfader)
http://img273.imageshack.us/img273/8091/crossfaderleft3qu.jpg
Mid Position:
http://img273.imageshack.us/img273/2716/crossfadermid5bi.jpg
Right Position:
http://img273.imageshack.us/img273/614/crossfaderright6yr.jpg
As you can see, if I put the Crossfader on the DJ Console to the left side, VirtualDJ only put it a litte bit over the middle ... and so on. Can you help me? Can anybody help me. I didn't find something in the forum. Sorry for my bad english.
THX
Mid Position:
Right Position:
THX
Posted Thu 22 Dec 05 @ 7:49 pm
answered under the other post you posted in the other forum. (I think your unit is defective)
Posted Thu 22 Dec 05 @ 7:54 pm
try update your driver and firmware (new update available at www.hercules.com )
the firmware update might fix your console
Posted Thu 22 Dec 05 @ 8:40 pm
