umm it says theres an error it cant conect to server 127.0.0.1
what should i do?
what should i do?
Posted Tue 20 Dec 05 @ 9:06 am
127.0.0.1 is a loopback address...
Posted Tue 20 Dec 05 @ 9:13 am
ok so then what do i do?
Posted Tue 20 Dec 05 @ 9:15 am
what do you want to do theturk? be on virtual dj radio?
if so its a little more difficult than that.
-gauge
-gauge
Posted Tue 20 Dec 05 @ 10:31 am
Is that not the address you use for multi-instances of VDJ so they can be synced?
Posted Tue 20 Dec 05 @ 2:54 pm
Yes it is.
Turk, What you want to do?
Posted Tue 20 Dec 05 @ 6:11 pm
oh i just wanted to go on it and stuff
i dont have a problem listening to it i have a problem djing on it
Posted Tue 20 Dec 05 @ 6:59 pm
i meen i want to be on the radio VDJ radio
Posted Tue 20 Dec 05 @ 7:40 pm
Turk, go to the radio forum (you have to sign into the site since it's prof level user only). There is a sticky that says "if you want to DJ on the radio". It's a process where you contact the radio team, who then setup a time to do a check of your system broadcast abilities and of course your dj abilities. You'll do a live mix with the radio teamer listening. Good luck.
Posted Tue 20 Dec 05 @ 8:52 pm
