Topic: having problem with recording!!
ramoonHome userMember since 2005
if i record a set then it is .wav
example 1 hour = 400MB big, wich is way to big for an hour!
how do change it to .mp3 so i can listen to it later, cause mediaplayer wont play it!!
so i can make the sets smaller and enjoy them later...
plz help cause i have to play on wedding soon...
thx
Posted Sun 18 Dec 05 @ 3:02 pm
Simply choose MP3 in the configuration for record.... :)
you will find recordsettings by hitting the button right over the "start recording" button
Posted Sun 18 Dec 05 @ 5:01 pm
