Forum: Old versions
Topic: problem with skins
i downloaded a skin for the first time, i opened it and it said that i needed to install VDJ. I have VDJ installed and it works fine... what am i doing wrong?
Posted Sat 17 Dec 05 @ 10:01 pm
Hey Saki...:o)
I'm pretty sure the skins aren't available for demo users. There are 3 default skins supplied I'm sure, but the only way you can update is if you either buy the full version virtualdj.com/purchase or update your profile with your serial number.
Cheers...and keep spinnin'...:o)
P
Some skins are for a newer versions of VDJ. Skins are for all users (also demo users) but you need a compaible version of VDJ and the current skins you are using.
