I'm using a Numark CM200 USB mixer with this software. In order for the music to be played at a high level I must have the Main and USB channel output volume level close to the top of it's range. Is there anything I can do to avoid having to do this with the software. The CD's or MP3's I play with my Denon DN4000 play at a lower channel level?
Thanks!
Thanks!
Posted Tue 13 Dec 05 @ 5:34 pm
Is the mixer recognized as a soundcard in Windows?
In that case, turn main output volume slider to the top there...
Also, what settings do you have for gain inside Virtual DJ ?
Setting auto-gain to "always zero" seems to be almost the level of cd players (a bit lower)
Posted Tue 13 Dec 05 @ 5:40 pm
Yes, the system recognizes the sound cards used within the Numark Mixer. I have the gain level within the software turned all the way up?
Posted Tue 13 Dec 05 @ 7:18 pm
NO...
it the configuration settings of Virtual DJ... try setting AUTO GAIN to "always zero"..
See if that gives a better level to your external mixer...
AND, in the control panel for your usb soundcard, turn the slider all the way up there, it its not :)
Posted Tue 13 Dec 05 @ 10:52 pm
