Topic: Turntables VS VDJ w/ Mixer
Hello all,
I have a question plz: Which of the following setup do you think is better for a radio DJ?
1) 2 Turntables with Time Coded Vinyls (and VDJ) with mixer
2) VDJ with 2 soundcards and mixer
Then, considering a low budget, do you still recommend your choice?
Thanks!
Posted Sun 11 Dec 05 @ 5:30 pm
For a low budget and a bedroom DJ, go with the sound cards, VDJ and a mixer.
But for a more professional look go with the TTs, TCV, VDJ and mixer.
I perfer the TTs myself being from the old school.
MS
Posted Sun 11 Dec 05 @ 5:46 pm
You could start with VDJ, a proper sound card (at least 5.1) and a mixer. You could buy some turntables and Timecode vinyls later.
Ewout
Posted Sun 11 Dec 05 @ 5:59 pm
abnormPRO InfinityMember since 2003
For a radio DJ, my choice would be just VDJ with one soundcard. All compact and easy. Internal mixer is more then enough for that.
Posted Sun 11 Dec 05 @ 6:37 pm
acw_djPRO InfinitySenior staffMember since 2005
Low Budget?...
DJConsole MK2 ... get a controller 2 USB Sound Cards and a VDJ Console Edition for about $250...
You could also use VDJ + 1 SoundCard 5.1 + Mixer... $149 + $ 39 + $119 = $307...
Think about it, but in your case, I buy DJConsole MK2.
Posted Mon 12 Dec 05 @ 7:09 am
the mk2 has a built in mixer right.. ??
Posted Tue 27 Dec 05 @ 6:39 am
