With the new Hercules Mk2, Virtual DJ 3.2 and the special timecoded vinyl, pitching, cueing, spinning, start-stop are all possible, just like classic DJ mixing or only works for scratching?
Maya 44 USB Card Sound is the better choise to work without the console?
Anybody knows? ...Thanks!
Posted Tue 06 Dec 05 @ 4:19 am
Yes, just like classic djing. The console is a soundcard as well so you wouldn't need both. for soundcards, yes the maya works well. there are also others that work. you can search the forums for soundcards and get a bunch of choices. hope to see you as a full member soon.
Posted Tue 06 Dec 05 @ 3:24 pm
