Hello again guys...
Can anyone tell me wich Firewire sound-card (For TCV's) is the best..? (I just realized that I got a firewire connection in my laptop.. :D )
Maybe a PCI-soundcard wich I can use with TCV's is okey too, tell me wich is the best one...
(I don't know if I got any PCI-"hole" in my laptop, you can look at all the connections I got on my laptop here http://www.the220.com/images/HP/dv1000/31000131-2-300-sides-4.gif and http://www.hp.com/hpinfo/newsroom/press_kits/2004/digitalexplaunch/images/dv1000.jpg /AND if you want to see the rest of my laptop you can see it here http://www.the220.com/notebook/pavilion-dv1000.htm )
If anyone has tested one, so please tell me... And just tell me about the soundcards wich is tested with VDJ.. I don't wan't any problems...
Just tell me all the possibilities I got... (I don't know so much about sound-cards and wich possibilities it is to connect one, so plzz help me)
I need a sound-card soon as possible...
I hope you understand what I'm talking about
Thanx
Thanx
Posted Sat 03 Dec 05 @ 11:48 am
The Maya44 works fine. USB connection. I have three laptops. One with timecode and the Maya. Two others with gigaports. Maybe someone can reccomend a firewire out there for cash.
Posted Sat 03 Dec 05 @ 3:40 pm
laptops never have PCI-holes (as you put it), so don't buy a PCI-soundcard for your laptop.
Posted Sat 03 Dec 05 @ 5:02 pm
But it is a hole in my laptop :p /AND isn't a Wireless internet-card (for laptops) a PCI-card..? because my aunt got one, in her laptop...
but shit da same...
I tried to find a Maya 44 and I found one... When I called the guy, he said that he had sold it....
U can't find it in stores.. and I have searched for one all over the internet, in two countries man... Sweden and Norway... without result :(
What can I do..?
but shit da same...
What can I do..?
Posted Sat 03 Dec 05 @ 6:21 pm
You are looking for a pcmcia card like this
http://www.zzounds.com/item--ECHINDIGODJ
The problem is that you need inputs for tcv.
There are very few that have inputs to start with.
I know of none that are pcmcia.
My best advice is to find a maya 44 usb (proven to work) and use the pcmcia slot for music data either firewire or usb, but seperate the source from the output.
Don't try to use a usb sound card and a usb external drive together.
Still are available at Musician's friend
http://www.musiciansfriend.com/srs7/g=home/navigation?q=maya+44
Posted Sat 03 Dec 05 @ 6:38 pm
thanx mp3jrick..
Man musicans friend isn't in sweden.. :( so it's a lil bit difficult to buy from there... but thanx, I will take a look at the site.. :)
Posted Sat 03 Dec 05 @ 7:04 pm
I'd be happy to send it to you if this is the only source.
I just wanted to show the availability.
Laptops have some limitations in this area.
Posted Sat 03 Dec 05 @ 8:08 pm
yeah, you are right there...
I only got three USB-ports (one of them are not working, so I bought a HUB with power, 4-port)
Therefor I want to use a Firewire soundcard...
Maybe I will buy the soundcard from Music Friends..
Do you know how long time it takes untill I recive it, IF i buy it..?
Thanx again
Thanx again
Posted Sat 03 Dec 05 @ 11:07 pm
