Have noticed this has been an on-going problem in VDJ 1.09 and in past versions, that the mp3s DO NOT hold a constant volume whilst be mixed.
this is quite annoying as its a visible fading and change in the volumes whilst the mp3 is being played.
mp3s play normally with no change in volume via winamp.
i have sound blaster audigy and a sound blaster 128 in my pc.
therefor i would say its not the quality of my sound cards.
can someone please advise what is the best form of action to fix this highly frustrating problem.
Posted Thu 15 Apr 04 @ 12:36 am
Disable the limiter.
Posted Thu 15 Apr 04 @ 2:07 am
limiter.
can u explain where this is located, and what the 'limiter' is limiting?
Posted Thu 15 Apr 04 @ 3:46 am
As taken from the VDJ Users Manual: (The one we all get in PDF format upon installation of VDJ)
Page. 44
Limiter: Automatically limit the gain so that the sound will never go above 0dB.
It is located in your settings under the FAME settings tab, it is the 8th button from the top.
Regards;
Redman247
Page. 44
Regards;
Redman247
Posted Thu 15 Apr 04 @ 8:03 am
