This is kinda of a pain in the butt. i cant scratch the record without stoping the whole song i would like to scratch the beat and still have the voice going because i chop and screw music and this is a key factor in doing music for me. If you could can you reply some tips for me
Posted Wed 23 Nov 05 @ 7:48 pm
You should have the part you want to scratch (the beat and maybe the instrumentals) going on one deck while the voice (acapella) is going on the other deck. If you can't get separate instrumentals and acapellas for the track you need, then try loading the same track on both decks and apply voice canceller FX on one and instrument canceller FX on the other.
Posted Wed 23 Nov 05 @ 9:06 pm
Use seperate acappella and instrumental versions. That's your best bet.
Posted Wed 23 Nov 05 @ 10:04 pm
