I'm new to this software, how do I use the headphones to mix? Is there a need for two sound cards or is there a setting I need to make. I currently have 1 card that is a 7.1.
Moderated by ACW. You write this in other post (that is deleted because is repeated).
I recently purchased v.dj 2.01 for my desktop. I use it for my own amusement and need to know how I can use the headphones to mix. Do I need 2 sound cards, I currently have 1 that is a 7.1 card.
Posted Wed 09 Nov 05 @ 3:40 am
Posting multiple times won't help you get an answer faster although if you purchased the version of VDJ you should update your profile.
once you updated your profile you will then get the help to use the headphones. Otherwise I will answer as everyone else does.
Headphone use is disabled in the demo version. You will get this option in the full version
Best Regards
DJ White Devil
Best Regards
DJ White Devil
Posted Wed 09 Nov 05 @ 3:53 am
demo version doesnt let you. this only works on the full version. a bargain at under 100 pounds
Posted Wed 09 Nov 05 @ 4:07 am
Posted Wed 09 Nov 05 @ 4:24 am
