I'm not sure if this issue is with my sound card, laptop or the software setup. I told Audiotrak but they said they had never heard of the problem.
Anyway here goes.
The inputs seem to swap for no reason when I use the TCV's. So one minute the left vinyl is matched properly to the left deck in vdj then for no reason it will just change to controlling the track on the right.
The same thing happens when using the trail version of dj decks aswell.
My laptop is a compaq N410c 1.2Ghz P3, 256mb Ram with windows xp pro. I'm using Maya44 with virtual dj vinyls.
Anyone have any suggestions?
Anyway here goes.
Posted Thu 03 Nov 05 @ 7:07 pm
Its because this feature doesn't work in the demo.
https://virtualdj.com/forums/39781/Software_Technical_Support/Sound_Configurations_in_Demo_version_of_VDJ.html
Posted Thu 03 Nov 05 @ 7:32 pm
