Im currently using the trial version, and before I purchase the orgianl version. Can somebody tell me is it possible to connect my labtop via a USB port with a RCA x2 output to a dj mixer so that I can play via a mixer and still have 2 turntables running side by side.
If so what cable do I need and where can I get one from
Posted Thu 27 Oct 05 @ 11:45 pm
yeah its possible u can use a usb sound card :P
Posted Fri 28 Oct 05 @ 12:05 am
Any audio store sell the cables you require. Most USB sound cards works ok with virtual dj. And yes, you can use your regular TTs, as they require PHONO, so just flip between line and phono to use either the program or vinyls.
Posted Fri 28 Oct 05 @ 12:17 pm
