I need an alternative soundcard. I can't find the Maya44 anywhere. If I get the Numark USB Mixer, will i be able to use TCV,s with it?
Posted Tue 25 Oct 05 @ 7:50 pm
try musiciansfriend.com just bought a maya44 tewo weeks ago
Posted Tue 25 Oct 05 @ 8:40 pm
You would be better off buying a Maya44 than trying to use the Numark USB for TCV use. The Numark USB is not flexible enough to offer the right configuration for TCV use with VDJ. Not sure why you can't find Maya44USB, .. they are everywhere.
Posted Tue 25 Oct 05 @ 8:41 pm
everywhere...? no..
musiciansfriend.com and thomann.de must be the last..
Posted Wed 26 Oct 05 @ 3:39 am
I bought 2 Maya USB from Musicianfriend today... http://www.musiciansfriend.com/srs7/g=dj/search/detail/base_pid/700355/
Posted Wed 26 Oct 05 @ 6:18 am
I thik Creative Audigy2 external USB will bee O.K.
Good mix!
Good mix!
Posted Thu 10 Nov 05 @ 3:31 pm
