I really need your help to this. I bought a 200 GB HD IDE and replaced an 120 GB HD in a USB box. When i pluged the USB cable in to my Laptop it was recognized as Disk Starage or something and said it's ready to use. BUT when i open "My Computer" or any other program it does not show it. The same thing happens if i plug in to PC. I did not change anything, it worked fine with the 120GB, what happened? BIOS, Drivers , all updated and SP2 too. Please any ideas?
Thanks
Thanks
Posted Sun 23 Oct 05 @ 1:23 am
You have to place a letter to that drive... for that go to My PC and right-Click it. Select Manage or Administrate (The option number four from top to bottom)... You open something like "Equipment Managment" in there select "Disc Managment" look for your USB disk and change the letter to enter or maybe you need to create a partition and format the new drive.
After doing these your disc will be ready to use it.
Posted Sun 23 Oct 05 @ 3:15 am
Yeah... a new HD is not partitioned, it's only raw space; your PC "percept" it but since the HD doesn't have a logical unit you cannot "see" it. You have to make a partition (with Partition Magic, or fdisk, or else) and than format it.
Ciao!! :)
Ciao!! :)
Posted Sun 23 Oct 05 @ 3:37 pm
Control panel/administrative tools/computer management/disc management
You will find your drive listed but un allocated.
Right click on it and follow the prompts.
It will advise you on the partition, just click the recommended size and quick format.
It should come back unshaded and then will appear on your list of drives in my computer.
It will assign the drive letter which you can change later.
I usually title my drives with what is on them, audio, video 123 or karaoke etc...
Posted Sun 23 Oct 05 @ 4:28 pm
Food for thought...
And hopefully this is not the case in your situation...but...
The IDE to USB bridge electronics in the external box
have limitations. The earlier the manufacture of the box,
the lower the total capacity. The boxes I have been
purchasing lately are certified for up to 400GB. Some of
the earlier boxes are good for only 120GB or 250GB.
My suggestion to those with "older" external enclosures
is to upgrade now to ones with the "latest" higher HDD
capacities. 400GB caps are plentiful. They work fine
for my 320GB drives.
Very good point Tom.
Going to Vegas?
Going to Vegas?
Posted Sun 23 Oct 05 @ 4:35 pm
Still pondering that one.
Posted Sun 23 Oct 05 @ 4:47 pm
Me too, not sure what is going on with the booth yet.
Posted Sun 23 Oct 05 @ 4:49 pm
thanks for the advices, i had to format the disk first, i did not know that. I did not do it with the 120 GB because it was inside the PC before i put it in the USB box. Problem solved..Thanks a lot !!!
Brand new HD ready to receive Video Clips !!!
Posted Sun 23 Oct 05 @ 11:53 pm
