I was playing a little with it last week and found out that
even when you use USB cable and mixer is digital, the sound from PC is converted to analog
in the mixer and then again digitized.
The other thing is when recording to pc i must limit the otuput to at max HALF OF THE range
in order not to get distorted.
So there are 2 mods I plan to make:
1. Lower the recording sensitivity in order to not get distortion while playing loud.
2. Change the recording behavior to be able to record LINE/PHONO in while listening sound from USB soundcard. This way you'll be able to use TCV/TCCD without any additional soundcards.
I can probably make some photos and HOW-TO's
So anyone interested?
Any other ideas ?
Any other ideas ?
Posted Wed 19 Oct 05 @ 11:35 am
Great Lopez!,
Of course I'm interested...
Posted Wed 19 Oct 05 @ 3:19 pm
Sure Lopez......I have the same mixer.
Posted Wed 19 Oct 05 @ 3:39 pm
ok i'll create a docs :-)
Posted Wed 19 Oct 05 @ 4:12 pm
