I need to help in the Broadcast!
How can I do "Broadcast from my own computer!"
Help PLZ
THX POSSY
Help PLZ
THX POSSY
Posted Sat 15 Oct 05 @ 10:13 pm
good question.. i realy would like to know how to dj on the virtual dj radio.. i've tried to use the 'become a member' link, but then it says "not available at the moment".. so if anyone would know.. please help us
right now im listening to acw_dj on the radio.. well done
Posted Sun 16 Oct 05 @ 8:26 am
Thanks for listen Seany... I do some mistakes :S. For mix on the radio you need to be a professional user. If you buy VirtualDJ you gain the professional user level. After you are a professional user you need to request be a member of the radio to a radio teamer.
Posted Sun 16 Oct 05 @ 12:03 pm
If you want to try your hand at another radio station, do read my tutorial on the topic:
https://virtualdj.com/forums/41884/General_Discussion/How_to_broadcast_Internet_Radio__tutorial_.html
Posted Sun 16 Oct 05 @ 4:03 pm
thanks.. yeah when will you be next on acw? me and my friend were listening to it most of yesterday it was awsome. thanks.
my trial version runs out in 4 days.. so i'm going to buy it then..
happy mixing ;)
happy mixing ;)
Posted Mon 17 Oct 05 @ 1:44 am
See you around Seany. I will welcome you as a full member in 4 days ;-). Thanks again for listen my mixes.
Posted Tue 18 Oct 05 @ 7:21 am
