I currently use the Maya EX into my clubs mixer with no problems and very simple set up. I am trying to use the Maya 44 USB for a gig this weekend with my laptop, but cannot get it to work. What is the actual config necessary to just get VDJ to play into a mixer from your laptop? No vinyl will be used. I just need to hook the soundcard into the two channels of a basic Rane Mixing board. I mix using the mixing board as well as the headphones from the mixing board. Please help.
Posted Tue 11 Oct 05 @ 7:33 pm
I'm using the 4.1 setting... works for me, but advanced config works aswell.
Posted Tue 11 Oct 05 @ 8:28 pm
Could you be more specific. I have tried everything, and cannot get this card to work on two seperate channels of the mixing board.
Posted Tue 11 Oct 05 @ 8:34 pm
Not sure if I'm understanding correctly how you are trying to set up. I use the card and it works. I have the TCV though. I don't have my stuff with me so I'm trying to go from memory. I have the TT's going inputs 1-4 and the outputs 5-8 going back to my mixer. 5&6 to one channel and 7&8 to the other. The config setup is in cstoll's blog I believe regarding the asio setup. first two sections are muted...the last two sections are about 3/4 if I recall.
Posted Tue 11 Oct 05 @ 8:39 pm
Here is dams' blog that has info as well.
https://virtualdj.com/blog/Dams/blog738.html
here is cstolls - should be all the info you need
Thanks to both of them for putting together good info on using this card
Posted Tue 11 Oct 05 @ 9:25 pm
Here is how mine is setup. I have the 2 decks output directly to the mixer so I can use the crossfader on the mixer instead of in VDJ. Just leave the crossfader in VDJ in the middle.
Hook up the Maya 44 to your mixer like this.
Output 1 - Left of Deck 1 in your mixer
Output 2 - Right of Deck 1 in your mixer
Output 3 - Left of Deck 2 in your mixer
Output 4 - Right of Deck 2 in your mixer
In VDJ
Config | Sound Cards
Pick Advanced and click the Advanced Config button
Left Deck
Maya44USB Asio Driver --- Out 0 - Maya44
Maya44USB Asio Driver --- Out 1 - Maya44
Right Deck
Maya44USB Asio Driver --- Out 2 - Maya44
Maya44USB Asio Driver --- Out 3 - Maya44
Enjoy...
In VDJ
Left Deck
Right Deck
Enjoy...
Posted Wed 12 Oct 05 @ 6:47 pm
